  1. Dear Videohelper,
    I need to convert some of my old VHS Tape into DVD Video.
    How & what I need to do, step by step ?
    I have these Hardware :
    - VHS Recorder with Scart
    - PC with firewire connection, enough Hardrive & DVD Burner
    - Terratec Cinergy XS ( http://tven.terratec.net/modules.php?op=modload&name=News&file=article&sid=236 )
    - MiniDV camcorder
    - S-Video Cable, Composite Cable
    Cheers
    need any video help !!!
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by laptopuser
    D
    - MiniDV camcorder
    Look in the manual and see if there is any directions for converting analog to digital, it may also be referenced as pass through. If it has that feature you only need to connect your VCR to it which will convert to DV-AVI. Capture over firewire as you would normally for DV tapes.
  3. Originally Posted by thecoalman
    D
    - MiniDV camcorder
    Hi "thecoalman" thanks for your quick answer.
    So my Terratec Hybrid Cinergy XS wont do ?
    My Camorder Model JVC GR-DVL157E
    Ehmmm .... you meant should I put a MiniDV Cassette on my Camroder ?
    So the step, turn on my VCR , put the VHS Tape & Play it ?
    Then connect my VCR with my CAMCORDER using S-Video or Composite ?
    Later Turn on my PC & connect my PC with my CAMCORDER "connect with firewire" ?
    Btw. can I do it by using Nero ?
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I'm not familiar with that card but the DV cam will undoubtedly give you a better capture. I looked your model up and it says it supports pass through. You'll need to look it up in the manual on how to do it, directions vary by model. The chain is the same though:
    VCR>> RCA Cables(S-Video if you have it) >> Cam >> Firewire Cable >> Firewire Port on computer .
    I'm assuming you have transferred video you have taken with your cam already via firewire? If not you may want to start there instead.
    You don't need a tape to do passthough. The cam is only used to convert the analog signal to digital.
  5. Originally Posted by thecoalman
    Thanks again for your reply
    For that JVC Camroder, it has 2 models , one "with E" & the another "without E".
    In which position should I do with my Camcorder as pass through ? REC or OFF or PLAY ? Better it connected with Electricity right ?
    I will give a try, but need to find my Manual first, coz dunno where I put it now :-p
    Do I also need to install some file in other to make it work, in order to encode from analog into digital ?
    Like someone mentioned in this website http://vhs-to-dvd.janvesely.com/video-grabbing.php ?
