    Feb 2007
    Singapore
    Hi
    How do i queue files in Virtual Dub Mod?
    I currently can only process one file at a time and have to manually come back later to process the 2nd and 3rd job etc..
    i am using it to add subtitles to a drama series via TextSub
    Regards
  2. Member rhegedus's Avatar
    on the jazz
    When you go to 'Save as AVI' (F7), tick the box in the bottom left corner that says 'Don't run this job now....'
    Continue to do this for all your projects then got to File > Job Control (F4) and you should see all the jobs you've scheduled.
    Click Start.
    Regards,
    Rob
    Feb 2007
    Singapore
    thank you so much!
