  1. 31 y/o newb to all this stuff.
    I've successfully burned VCD's for play on my Sony 400NS. However, it doesn't play SVCD's.
    I recently downloaded 4 nice little SVCD's. I can view the MPG file with PowerDVD no problem.
    My question is, can I take that MPG file and some how burn it into a format on DVD that my DVD player will accept?
    I have access to both a Pioneer A03 as well as a Panasonic DMR-E20K/S (forget which exact model - http://www.prodcat.panasonic.com/shop/listmodels.asp?categoryid=1375&CategoryDesc=DVD+...ideo+Recorders - one of those 2)
    What I would like to do is create a "pop in and play DVD" - nothing fancy, just go. I know at this point, I could just burn the MPG's to a DVD-R, and just play them in my computer's DVD player using PowerDVD to read the media files.
    I looked pretty far back, and didn't see any posts asking this sort of question, and the guides that I saw, didn't cover this "area" as well.
    Basically, I don't want it to be VCD/SVCD format/layou on the CD. I would like to take the MPG's as is, and "author" (? - that right) them onto a DVD-R, in one long fat file, that I can pop into the DVD player and watch it.
    We also have a pretty decent video editing suite at work
  2. You can either convert the SVCD into a VCD, see the guides
    or you can convert into DVD, again I think Baldrick has a guide for this now, not sure.
    Give the "How To" section a very good thorough reading.
    Best is to convert to compliant dvd format
    www.vcdhelp.com/mpeg2tovcd.htm and choose the dvd ntsc template instead of vcd.
    Or you could make a xDVD that may work but it doesnt require any reencoding of the video
    www.vcdhelp.com/vcddvdr.htm
