hi need some help they give me a GIGABYTE motherboard GA-8N-SLIRoyal LGA775 ok what i like to know is if i buy (Intel Pentium D 935 3.2 GHz) will it work with the motherboardand ? and what Brand of Memory is best to get & size: Kingston? DDR2? for the motherboard ( Newbie ) Please if anyone can help would be much appreciated thank you THANKS![]()
It is not supported
BTW, Gigabyte has a support site that lists details about their products. Here's the link for CPU support http://www.giga-byte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1898
and the main page for that Motherboard http://www.giga-byte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1898 -
From your link:Originally Posted by disturbed1
Supports LGA775 IntelŪ PentiumŪ D -
It only supports the D830 and D840. It does not supports the D900'sOriginally Posted by tekkieman
Should I re-upgrade from Asus/AMD to Gigabyte/Intel?
By Stealth3si in forum ComputerReplies: 23Last Post: 16th Apr 2012, 21:06 -
HP Laptop help (Is Intel motherboard worth $200 more than AMD?)
By jyeh74 in forum ComputerReplies: 9Last Post: 13th Dec 2009, 16:48 -
Intel 850 motherboard help
By frieday in forum ComputerReplies: 6Last Post: 12th Oct 2009, 14:27 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58 -
Intel New Media Series Motherboard
By jmbadu in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Jul 2007, 23:23
