Ive searched the web, fiddled with MSP8 for days, cant seam to figure it out.
I have a JVC camcorder, I shoot video mainly in 16:9 for widescreen. The captured file from the camcorder's hard drive is an MPEG2 720X480 16:9 aspect ratio file.
I use Ulead Media Studio Pro 8.
I want to output the video in 720X480 (or even 320/352X240) in 4:3 aspect ratio WITH letterbox. This is mainly for web streaming where 16:9 cannot be used.
No matter what I do, the resulting file has the 16:9 STRETCHED to fit in the 4:3 aspect with the same 720X480 resolution, and NO letterbox.
I give up... Someone save my sanity please!
Thanks, Andrew
I did figure a way to take the final 16:9 file (MPEG) as created from MSP and run it through VirtualDubMod to resize it, add a letterbox and output to an AVI file. I can encode again with TmpgEnc for a new file. Its not totally lossless, using XviD I turn the bitrate up high enough to not loose detail and it works good.
I would still like a "one stop shop" solution for MSP if anyone knows of one. The above method works GREAT, but adds a few more steps and a LOT of encoding time for the desired result.
Thanks,
Andrew -
SlInGeR, the first part doesnt work, tried that 50 different ways from Sunday.
I cannot find how to resize a video within a project, can you describe how?
Thanks,
Andrew -
I figured this out, using a moving path 2D custom, I was able to resize a clip within a project and it letterboxed like I wanted. I saved it to custom so I can pull it out with the predefined settings easily.
Can I add a moving path to an entire project or will I have to add it to every clip in the project to get the final results I want?
Thanks,
Andrew -
Regarding Ulead MSP8:
Thanks,
Andrew
Widescreen Output Using ATI Theater 650 Pro and Ulead VideoStudio X2
By waldodiodio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 11:00 -
Ulead Videostudio Output a Bit Big?!
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 14:47 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
ULead Video Studio output MPG incompatible??
By TJohns in forum EditingReplies: 0Last Post: 27th Aug 2007, 05:05
