Hi everyone,
Here's a script I am using but I need to know how to extract the audio into a wav taking into account the trims in the script to ensure the audio matches the video. Can I use VirtualDubMod -> Open avs -> demux to wav?
avs -> m2v using HCGui
avs -> wav using VirtualDubMod
avs:
LoadPlugin("degrainmedian.dll")
LoadPlugin("fft3dfilter.dll")
LoadPlugin("ColorMatrix.dll")
LoadPlugin("AudioLimiter.dll")
LoadPlugin("soxfilter.dll")
loadplugin("SoundOut.dll")
avisource("E:\Orginal with audio -480ms delay.AVI",audio=true)
AssumeFPS("ntsc_video",sync_audio=true)
SSRC(44100)
scene1 =Trim(101,4458).Fadeio(30)
scene2 =Trim(4511,20608).Fadeio(30)
scene3 =Trim(20609,23516).Fadeio(30)
scene4 =Trim(23517,25424).Fadeio(30)
scene5 =Trim(25425,34760).Fadeio(30)
scene6 =Trim(34761,36732).Fadeio(30)
scene7 =Trim(36733,40836).Fadeio(30)
scene8 =Trim(40837,59642).Fadeio(30)
scene9 =Trim(59738,76154).Fadeio(30)
scene10 =Trim(76155,80016).Fadeio(30)
scene11 =Trim(80017,85680).Fadeio(30)
UnalignedSplice(scene1,scene2,scene3,scene4,scene5 ,scene6,scene7,scene8,scene9,scene10,scene11)
ConvertToYV12()
DeGrainMedian (interlaced=true, limitY=4, limitUV=6, mode=5)
FFT3DFilter(interlaced=true, bt=3, sigma=3.0, plane=0, bw=64, bh=64, ow=32, oh=32)
ColorMatrix(interlaced=true)
Crop(0, 8, -0, -8) #crop 8 lines off the bottom
AddBorders(0, 8, 0, 8) #add 8 lines of black to the bottom
ConvertAudioToFloat().SSRC(41000)
fl = GetRightChannel()
fr = GetRightChannel()
cc = mixaudio(GetRightChannel(),GetRightChannel(),0.707 ,0.707)
lfe = GetRightChannel() #ConvertToMono(a).SoxFilter("lowpass 120","vol 1.2")
sl = GetRightChannel() #.amplify(-1.0)
sr = GetRightChannel() #.amplify(-1.0)
sl = DelayAudio(sl,0.02)
sr = DelayAudio(sr,0.02)
MergeChannels( fl, fr, cc, lfe, sl, sr).wavgainlimiter(1.0)
#SoundOut(output = "ac3", filename="Surround.ac3", autoclose = true, wait=0, overwritefile="Yes", showprogress=true, cbrrate = 384,acmod=7)
SoundOut()
Thanks,
Chris
I would try fixing it before you do all of the trims, but you can try
DelayAudio(-0.480)
in the script
or is it without the "-"
try both. -
Sorry Soopafresh. I have already added the 480ms delay so the sound is in synch to the video in the avi: E:\Orginal with audio -480ms delay.AVI
Is the soundout() function smart enough to use the video that the avs script has for the audio? IE: Will there be audio for frame 4500 or will it be trimmed like the video is?
Thanks,
Chris -
Ah, I now understand what you're asking. I believe the answer is yes. You can always process both separately using the killvideo() and killaudio() commands, respectively. Try killing the video, then seeing if the audio trims in the right places.
Noob needs help trimming, splicing, audio with AviSynth
By PapaDmitry in forum EditingReplies: 39Last Post: 6th Jul 2010, 10:53 -
Trimming the audio to go along with the video cuts in avisynth?
By mt123 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 04:23 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:22 -
extracting audio and changing it
By usermm in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 15:41 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 20:03
