Hi. I've been wanting to do this certain effect for a while, but I can't figure out how to.
It's like a slow-mo effect, but it seems almost choppy and blurry. You might see it in a scene where someone dramatically drops a glass or something (:P)--like that slow, almost dazed effect.
Do you know what I'm talking about?
If so...Does it have to be done before the editing process on the computer? If not, what program is capable of this?
Thanks.
Fairly basic, but if you have a AVI or you use VirtualDub, or VirtualDub Mod with a MPEG, and convert to AVI, just use 'Video>Framerate' and change the 'Source rate adjustment' to a low value, say 5fps, then in 'Frame rate adjustment', change it to a proper value, say 29.70 for NTSC or 25fps for PAL. Then use 'Save as' to make a new file. It will look a bit choppy, but that seems what you want. The audio will be lower/slower too, so you might not want to use it.
Play with it a bit to get a good effect. You can also add many, many filters available with VD that can change the output and appearance.
And welcome to our forums.
Thank you very much (both for the advice and the welcoming)!Originally Posted by redwudz
Edit: No wonder I couldn't do it. Ulead VideoStudio 9 can't pull something off that a free program can, apparently. >:|
But VirtualDub looks like a worthy competitor to any piece of budget software.
Edit 2: Oh, so it does automatically make certain things URLs. Heh. -
You mean when you type in the name of a program? Yes, if they are listed in our 'Tools' section, it will link to them.Edit 2: Oh, so it does automatically make certain things URLs. Heh.
VD is a great tool. It has hundreds of filters available, can edit, encode, filter and frameserve to a MPEG encoder. And there are lots of guides available at the bottom of it's tool page. Kind of the 'Swiss Army Knife' for AVIs.
Well worth learning.
Frame Rate/23.976 vs. 29.97
By mltwitz in forum Video ConversionReplies: 11Last Post: 20th Dec 2012, 07:23 -
DV to h.264 for live streaming at low bit rate?
By VidQues in forum Video ConversionReplies: 1Last Post: 22nd Mar 2010, 07:56 -
Is low bit rate mpeg2 (1200kbps) compatible with all DVD players?
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2008, 07:49 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
