Hi,
I am using PixelView PlayTV pro since a couple of years and it works great for viewing cable TV. I want to use it for viewing Satellite receiver output with RCA cable (composite video), but it does not work (source is set to Composite video). In the "Video Capture filter..." dialog, "VCR input" option is disabled. I have no clue why is this option disabled and how to activate it. I am using "PlayTV ver.3.2 TV" software under Windows XP and I installed the drivers from the installation CD provided with the TV card.
Any help in this regard will be highly appreciated.
Cheers,
				Results 1 to 1 of 1
  DVP3100V - composite/SCART signal correctionBy Annihlator in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Dec 2010, 05:56
  What video cards support S-Video & Composite output over VGA via adapters?By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57
  How to Split NTSC Composite Video signal ?By SingSing in forum RestorationReplies: 16Last Post: 26th Jan 2009, 11:50
  Canopus AceDVio composite capture problem (Svid works, but not composite)By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55
  Composite IN vs S-Video IN (using converter wire composite to s-video)By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
