Hey everyone!
I'm trying to edit two 6 minute clips together in Premiere Pro CS3. The video playback is quite choppy, and nothing I do seems to work. The clips are both .avi files (mpeg v3, PCM audio). I defragmented my hard drive and it didn't help. I'm using a Dell Inspiron 5100 Laptop... 2.66GHz pentium 4 with 1gb of RAM.
Any Ideas?
-Justin
mpeg v3? or do you mean mpeg4 v3?
Are they choppy in the viedo preview? or also when export the video? -
Try export and see how it looks like. And if it's still chopppy I would use Virtualdub and open the avis and export to another video format like uncompressed avi or dv and then import in Premiere.
Since Premiere Pro 2, specific codecs in the AVI format will just NOT playback. This has nothing to do with your system.
I don't know why, but since version 2, they've made the program SUPER picky about what it wants to playback. Anything outside of DV nearly doesn't work.
The only way to fix this this would be to convert the files to DV first. Then edit that.
I myself still have the old Premiere Pro version 1.5 kicking around, because it's the only version that works with other codecs (such as Huffy) properly. I have a pretty powerful system, and I can't even playback Huffy AVIs inside Premiere Pro CS3. The program just doesn't want to.....
Premiere Pro Playback issue
By cabalwars in forum Software PlayingReplies: 2Last Post: 29th Dec 2009, 16:56 -
Premiere 6.5 - Playback stops after 20 minutes on NEW PC.
By Phase52009 in forum EditingReplies: 0Last Post: 29th Jan 2009, 19:55 -
Playback is too fast in Premiere Elements 4
By GermWarfare in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2008, 20:25 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
Choppy Avi Playback in Premiere
By eccentricfeline in forum Newbie / General discussionsReplies: 6Last Post: 24th Aug 2007, 12:10
