Is there a reason Not to buy a motherboard with a WiFi ???
when you get a new rig that will be for general use and editing.
The is another laptop aroung and an OLD [mostly internet and Office] computer.
I was thinking of the new P35 chipset. IWhat are your thoughts? and Which brend ?
Look into antenna options, available for use with the MB. Good antennas are essential. Look at the mechanics of mounting the antenna.
Beyond that - remember that WiFi is prone to various types of interference, bringing the interface into the chassis may yield results which are inferior to cabling to a router, due to RFI within the box, generated not only by the MB but all of the internal components. -
P35 is a great Chipset. If you want to install Vista, you may find out that your disk will not be supported for installation purposes. This is a problem with Vista and Intel SATA drivers. This actually happened to me with an Abit IP35 board and a WD 150 Raptor hard disk.Originally Posted by Dash1
For brands I prefer ASUS and Abit.
Other than this my machine has been rock solid.
Regarding the Raptor HD, I manged to use it bu installing Vista using a old PCI SATA card. After Vista was up and fully patched with MS and Intel updates, I moved my Raptor to the onboard SATA ports. -
So. do many stay away from the WIfI option ? 'couse of reception and anntena ?
Also, If I will not use it for gaming [ no sli OR oc] so no new games that can
use the Quad and no Vista ,IS THERE ANY REASON TO SPEND ON A QUAD ??? -
Regarding the wifi. I do prefer PCI network cards that I could upgrade with better antennas and drivers avialblr for the operating system that I use. If the internal wifi card do support upgrading the antenna, I think you should be OK.
When you say "editing", What do you mean?Originally Posted by Dash1
Editing video and converting from one format to another?
I do a lot of video transcoding from AVI DV to MPEG2. This is the reason I got a Quad core. For games it would be a better option to get the fastest dual core that could be afforded.
If by "editing" you mean word processor, definitely you do not need a quad core. For XP at least get 1 GB RAM and for Vista future prof, get 2 GB RAM. -
Thanks. any more opinions on the WIFI on mobo ?
I also will be useing it for home video editing inc.
capturing from old VHS and mini DV both NTSC and PAL.
No real benefit from a quad CPU , right ? -
I just put together a new machine, and found quad core to be very reasonably priced and well worth the money. For encoding it is amazing just how much of a difference it can make. Even for XP, 2 GB of DDR2 800 Mhz ram is a good investment.
As for WiFi, my view is that it is great for a laptop, and pointless on a desktop unless it is a HTPC sitting some distance from the router. You will get a more reliable connection over ethernet, and can get in to make changes even if the wireless isn't talking. I run two laptops and a desktop here, and the desktop connects via ethernet.Read my blog here.
WIFI AC and WIFI AD coming in the next few years
By yoda313 in forum ComputerReplies: 0Last Post: 31st May 2011, 09:01 -
Wifi Woes
By mmitcham in forum ComputerReplies: 6Last Post: 17th Oct 2010, 23:59 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47 -
wifi to ethernet?
By iThinkYouBrokeIt in forum ComputerReplies: 4Last Post: 31st Oct 2007, 08:49
