hi
i would like to play more mp3 songs with just 1 click in total commander
if i select in TC all songs by insert button on keyboard(make them red) it does not play all songs but only 1 if i press enter.
is there any way to setup Total commander so i could actually choose songs (make them red with insert button) and then just press enter and it will play all selected songs and not just 1 song?
thanks
	They have a forum on their website. You would likely get a response from there: http://www.ghisler.com/ Google is your Friend
  WMP 10 won't play CD's the audio is all choppy sounding, mp3's are fine..By J Tinsby in forum Software PlayingReplies: 3Last Post: 14th Dec 2009, 06:32
  total commander dont see folder with *stores your local website* signBy deejay.2001 in forum ComputerReplies: 0Last Post: 12th Feb 2009, 06:32
  iPod last.fm-type statistics program (total songs played in last week, etc)By Salva Veritate in forum Portable VideoReplies: 0Last Post: 22nd Jan 2009, 16:54
  Want to play mp3 songs in my car's cd player-what software converts it?By jbitakis in forum AudioReplies: 5Last Post: 10th Jan 2009, 09:59
  how to play selected mp3 songs with WMP11 in Total commanderBy deejay.2001 in forum Software PlayingReplies: 1Last Post: 7th Feb 2008, 10:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
