Results 1 to 12 of 12
    Oct 2007
    Canada
    Hi!
    I have a requestion regarding the playback of DVD-RIP. It might be dumb, but I frankly don't know what to do about it.
    I recently acquired a 22' widescreen monitor and use a resolution of 1680 X 1050. Whenever I play a DVD-Rip (that I get from the web), the image is a bit pixelated when I play it full screen. I will read comments from people saying that the video is of super high quality, but every one that I have downloaded, I have had that problem, some are worse than others. Is it just normal or is there a way to tweak the qulaity of the image. Whether I use WMP or VLC, there is no difference. I tried to check the options but couln't see anything related to that.
    I used to have a 17' monitor and the movies looked better as I can remember. Maybe, because the resolution was smaller so the pixels did not show.
    Please help, I just expected to have a better viewing experience with a bigger screen and it seems to be the opposite.
    Thanks in advance.
    Itachi75
    May 2007
    reality
    What happens when you play a store bought, commercial DVD from the same system to the 22" monitor?
    Oct 2007
    Canada
    The image is much clearer, pretty much what i would get to see on my TV...
  4. Member ntscuser's Avatar
    Mar 2003
    When you say "DVD-RIP", do you mean a 4.43GB DVDR file or a 700MB XviD file?
    Oct 2007
    Canada
    700MB XviD file
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    The key to your answer is "downloaded". You are not getting the same product that is on a DVD but a highly compressed format suitable for distribution over the web. Full DVD quality unaltered is going to run in the neighbohood of 5, 6, 7... GB's .
  7. Member ntscuser's Avatar
    Mar 2003
    700MB XviD file
    Was your previous monitor a 17" tube?
    Oct 2007
    Canada
    Ok, I thought that by ripping only the video and audio tracks, the video quality would be the same.
    Is there still a way to increase the quality of the playback itself?
    I'm using the Vista codecs pack...
    Oct 2007
    Canada
    Yes, the 17'' was a tube.
    May 2007
    reality
    You answered your own question. Garbage In = Garbage Out or GIGO. Stop expecting some downloaded DivX or XVid file ripped from a rental DVD to provide much meow factor. Super dupper, ultra extreme, never seen before quality!!! You in the market for a bridge???
  11. Member ntscuser's Avatar
    Mar 2003
    Tube monitors - even large ones - are much more forgiving of pixelated recordings. That's because an LCD screen has to process the individual pixels all over again.
    Oct 2007
    Canada
    Look dude, I'm simply asking a question. If you can't answer nicely, you DO NOT have to reply. Sorry if I don't have your enlightment!
    Thanks to all the other guys for the help.
