I have the Philips DVP5140/37. Before last night I had yet to run into anything that it would not play. However, I had some folks over last night and went to pop in a movie and it would only play the sound. It gave an error that said "Video Format not supported" .
The Video Compression Format of the movie was "MS-MPEG4 V2".
Is this because that format is an older format?
The firmware version on the Player currently is 37.06.77.02 and from what I can tell this is the most up to date firmware version.
So I guess my questions are;
1. Is there anything I can do to fix this so my player can play the MS-MPEG4 V2 format?
2. Is there a newer player that does play that format?
3. Or, am I stuck with having to convert any movies I have in this format over to a Divx format?
MS-MPEG4 V2 is an old MPEG 4 codec from Microsoft. It's not fully compatible with modern MPEG 4 part 2 (ASP) codecs like Divx and Xvid.
You might try using an AVI Fourcc Code Changer to change the fourcc code to Divx but I doubt that will work. It's likely you'll have to reencode with a program like AugoGK, VirtualDub, or AviDemux.
Philips DVP5140 support long file names??
By juanbosco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Sep 2012, 19:00 -
Philips DVP5140 Subtitle Recognition Question
By jeanpave in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st May 2010, 22:10 -
Philips DVP5140 questions (XviD, region-free, etc.)
By MrFriendly in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jun 2008, 18:40 -
one problme about philips dvp5140
By raid168 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Feb 2008, 19:18 -
Which DVD player is better, Philips DVP5140 or LG LDA-830?
By Tiger_Lion in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Sep 2007, 13:46
