Hi there,
Apologies if I've missed a post elsewhere that may answer my question. I am a complete newbie to all this, but thought I would try to get up to speed as I have recently acquired one of the new ipod nanos that will play video. I have tried the following way of ripping from DVD and encoding for ipod:
1) Ripped single VOB from the DVD using MacTheRipper.
2) Encoded for ipod using ffmpegx (tried the ipod h.264 640w preset, which I couldn't get to work, so used the ipod m-peg 4 480w preset instead).
The quality is good other than the fact that the audio starts to move out of sync from around an hour in to the film (a bit over half way in). Can anybody suggest a way I can overcome this? I've only used presets so far, so I guess the solution may involve me fiddling with some settings? I'd be grateful if any responses could be given in laymen's terms as I really am completely unfamiliar with any of this!![]()
Many thanks,
Becky
I don't have a video ipod, so I may be off base here (but nobody's chimed in yet, so I figured I'd give it a shot). That said, do you see an option to "decode with QT" somewhere? If so, try selecting it. Or if it's already selected, try the other option. In general, QT tends to be somewhat better at maintaining sync (but it isn't perfect by any means).
Also, if your bitrate is too high, that can sometimes cause oddball sync problems. If pausing, then resuming play restores sync for a while, then this can be a sign that excessive bitrate is your problem.
Kick Ass To Ipod encode Audio Always Out Of Sync
By ZenMystic in forum Video ConversionReplies: 5Last Post: 15th Aug 2010, 21:15 -
iTunes won't synch video to iPod...why?
By Jabroni4872 in forum Portable VideoReplies: 2Last Post: 16th Oct 2008, 23:57 -
What software are you using to rip/encode DVDs?
By dbone1 in forum Video ConversionReplies: 2Last Post: 21st Jun 2008, 02:39 -
Want to watch rip'd DVDs by hooking up MacbookPro to TV. Some audio Q's...
By marklight in forum MacReplies: 1Last Post: 23rd Apr 2008, 19:53 -
DVD rip /avi thru MTR /FFmpegX - get wavy lines
By BattyRoy in forum MacReplies: 5Last Post: 31st Aug 2007, 10:06
