I've been using Nero Vision 4 for awhile now to put a video clip of a movie as the backgroud to the main dvd menu. All I had to do was import the clip and the audio automatically came with it, but this dosen't seem to be the case with NV5. The video imports and sets as the background fine, but the finished product dosen't have any audio. If I play the clip using other programs the audio is there. I see an option to use 'No Audio' or 'Custom Audio, but when I 'browse' to where the clip is, nothing shows up as available. Also, the main movie audio works fine, it's just the menu I can't hear. Any ideas?![]()
Umm. Try typing in "*.*" when browsing for the audio. It will show all available files in the directory. Then choose the video clip you want the audio from. I only have Nero Vision 4 so I can't test if this works.
How to delete a menu & create/insert a new one with Nero Vision Xtra?
By snowseals in forum Authoring (DVD)Replies: 22Last Post: 26th Aug 2011, 23:03 -
Nero Vision 4 Audio Sounds Overdriven, Distorted
By norton833 in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2008, 17:23 -
No audio sound on DVDs using Nero Vision 5.3.3.0
By dweis in forum Authoring (DVD)Replies: 9Last Post: 25th Jun 2008, 18:06 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 15:28 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09
