  1. Hi,
    Here's my problem.
    I have a DVD containing one VOB data file (VTS_01_1.VOB) and of course all the auxilliary files.
    What I want to do is edit this file and burn it on a new DVD.
    DVD Decrypter sais it is not encrypted.
    So I copied it on the HDD and changed the extension to mpg, in order to be able to edit it with Tmpeg DVD Author.
    Now here comes the wierd part:
    This mpg file is not played properly by Tmpeg DVD Author, nor by Windows Media PLayer, or Nero Vision or AdobePremiere (it appears like a 15 second movie, while its real lenght is about 10 minutes and only a few frames can be seen).
    HOWEVER, Media Player Classic can play it without any kind of problem!!!
    But I need it to be played by Tmpeg Author, in order to crop it and burn it as a new VOB.
    So what in the world should I do in this situation? Has anybody had similar experience..?
    Dec 2006
    Here,where do you think?
    Use Vob2MPG on original ,then try to open in TDA.....
    " Who needs Google, my wife knows everything"
    Did you try use the "add dvd-video" and select the folder with the vob files in tda first? Because you shouldn't just import vob files and just rename to mpg wont help.
