I have several videos with RMV extension and i dont know how to convert, besides i have downloaded some video with RMVB format and real player said it got to download new codecs, but after few minutes real networks said there s no software to play this file, i cant get it
Look in the HOW TO - Convert section. There should be a few guides.
As for the file that won't play, it is likely corrupt or it isn't a real RMVB file.Google is your Friend -
Try using the REAL Alternative codec with Media Player Classic. If you install all of the stuff below you will be able to play just about EVERYTHING!Originally Posted by konig
Real Alternative
https://www.videohelp.com/tools/Real_Alternative
Haali Media Splitter
https://www.videohelp.com/tools/Haali_Media_Splitter
ffdshow
https://www.videohelp.com/tools/ffdshow
QuickTime Alternative
https://www.videohelp.com/tools/QuickTime_Alternative
Media Player Classic is installed with either Real or QuickTime Alternative
https://www.videohelp.com/tools/Media_Player_Classic -
thanks, i ve still tried the codecs because the file was deleted(the stubborn file) but i havent found in the "how to" section my request about converting RMV
Lotsa RMVB convertors these days but a simple to use one that I like is Aone Ultra RM Convertor. Does great converting RM and RMVB to DVD compliant files that I can then author with TMPGEnc DVD Author.....
pls. help: converting .rmvb files using ffmpegX
By Dolly in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2009, 15:32 -
problems converting rmvb files
By Kavelian in forum ffmpegX general discussionReplies: 13Last Post: 15th Jun 2008, 12:58 -
Converting .rmvb files problems
By Gilberts in forum ffmpegX general discussionReplies: 7Last Post: 14th Nov 2007, 18:17 -
Converting .rmvb to avi
By rayrayleeroy15 in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2007, 10:04 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 02:01
