Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 13 of 13
  1. Hey ChrissyBoy - just wondered what was in the pipeline for this great app...
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well I am working on various Addons to the program...
    The first wave of addons include:
    DVD2MPG: An advanced version of VOB2MPG where you can extract chapters or titles, choose audio streams etc but the main advantage here is that it will overcome the dreaded vobid change that plagues other "extractors"..
    MotionMenus: A component which creates motion menus for SVCD2DVD and actually allows you to replace the menus in already authored SVCD2DVD DVDs with a motion menu...
    PAL2NTSC: a simple wizardlike conversion of a PAL DVD to a NTSC DVD
    Batch Manager: a batch manager...
    I am maxed out at work at the moment but will be taking some timeout soon to focus on these... They are already written but need a fair bit of polishing up...
  3. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    That would be very popular.
  4. Looking forward to the batch manager
  5. Any new news about the Addon programs ?
    Hubba hubba zoot zoot.......... :)
  6. Member mr nice's Avatar
    Oct 2007
    Yeah baby yeah I look forward to the new add onns when they happen how about auto chapter selection just push a button and it creates the chapters for you.
  7. Originally Posted by mr nice
    You do know that chapters are available already?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  8. Member mr nice's Avatar
    Oct 2007
    No I didn't know, how do you do this?
    Nov 2005
    Open SVCD2DVD.
    Select Preferences and Settings...
    Under the Process group, select Other
    There you will find Chapter Point Frequency. Use the drop down list to make a selection for frequency of chapters.
    Then click Save as Default Setting to apply this change to all new projects or Apply Setting To This Project only.
    Good Luck.
  10. Member mr nice's Avatar
    Oct 2007
    Make a menu like this, were you click next to select a scene from the episode instead of watching the main menu. I did try what you said but nothing happened apart from it telling me to save my project.
  11. You can't do a chapter menu (yet). But if you set it up properly the DVD will have chapters inserted that can be accessed using the chapter buttons on your remote. You cannot yet specify chapter points except by regular time intervals.
    Dwight
    - Herm Albright
  12. Member mr nice's Avatar
    Oct 2007
    Maybe chrissyboy could add this option in the new version of svcd2dvd?
  13. Member mr nice's Avatar
    Oct 2007
    Any news on when the new version of svcd2dvd will be ready?
