Hello everybody,
I'm loking for small, quick, effective Virtual Video Recorder software. Unfortunatelly ATI Multimedia Center is not working under Windows XP Pro Service Pack 2 with newer ATI Radeon VIVO cards (Video IN/OUT only, no TV tuner).
I have downloaded dozens of TV and Capture software trials, but there is not effective software fully usable for me. (ATV2000, Blaze Media Pro, Icy-TV, VirtualDub, VirtualVCR, WinFast PVR, CyberLink PowerCinema, CyberLink PowerDirector, CyberLink PowerVCR, Fox Video Capture Studio, PICVideo MJPEG, WinTV PVR250-350, ChrisTV Lite, Beyond TV, and many other...)
Same software have same functions or same feature, but there is not All-In-One software as ATI Multimedia Center Video IN component.
Requested functions are (all is available and supported with all ATI_MMC):
- Configurable and config_saving of PAL (video system) and inicialization at start of software.
- Configurable screen size & aspect ratio (4:3, 16:10 etc...) and input video format size & aspect ratio (4:3, 16:9, 1:2 etc...) for correct displaying on all screen types.
- ThruWindow, ThruDesktop, VideoDesktop (transparent video over desktop, or video under desktop), all Overlay without CPU consuming.
- Video window or fullscreen preview (for realtime watching from Video_IN) with realtime deinterlacing without CPU consuming or normal interlaced preview in wordow or fullscreen without visible interlace effect video distortion.
- Realtime zoom of part of video window or part of fullscreen.
- Configurable presets and profiles for video recording.
- Easy video recording start at video watching in window or fullscreen, recording according to configured and selected compression preset (easy quick fullscreen/window switch with CTRL+F or doubleclick to video, and easy quick recording start with CTRL+R or REC button click).
- Realtime video recording to MPEG-1 (Video_CD or configurable system_stream, MPEG-2 (DVD or configurable system_stream), AVI (ATI_YUV9 native, DivX, MJPEG and all other installed codecs in Windows), configurable video format, resolution and video stream bitrate, and audio format and audio stream bitrate.
- Separate available video resolutions depend on selected video broadcast system (PAL or NTSC).
- Scheduler for software virtual video recorder with setting of start/stop time, video input, video/audio format, HDD location, stripping and etc...
- Manual video recording start for selected time and automatic stop after selected time.
- Making full resolution PAL interlaced/deinterlaced snapshots (720x576) from displayed video from selected Video_IN to more formats (JPG, BMP, TIFF, etc...)
- Predictable time for recording (days:hours:minutesec) according to free space of HDD partition and realtime free space and recorded video size displaying with configurable autohide of controll buttons and panel.
- Selectable stripped recording of video to more indexed/numbered video files and configurable stripping system (amount of video files and HDD locations).
- Automatic indexed/numbered filenames after video recording stop for quick using.
- Automatic indexed/numbered filenames for snapshots captured from Video_IN.
- Motion Estimation quality setting for recorded video.
- Detail MPEG-1/2 encoding settings.
- Configurable VBR or CBR video stream for video recording (mainly for MPEG-1, MPEG-2, AVI MJPEG and other).
- Video cropping setting for video recording.
- Video cropping setting for video preview window or fullscreen mode.
- Small control panel under video window with main controll buttons in window mode, with possibility of panel hide (F2 key in ATI_MMC).
- Small control panel or control buttons over fullscreen video at the bottom of fullscreen video with configurable autohide time and cursor autohide at fullscreen mode.
- Power management turning OFF at fullscreen Video_IN watching or recording (no screensaver).
- Contrast+Brightness+Saturation+Hue+Gamma setting in video window or fullscreen mode (TAB and Arrow keys in ATI_MMC) (same behaviour as classic TV receiver with OSD).
Please help me to find (or recommend me) ATI_MMC Video_IN component equivalent software with all feature as ATI_MMC.
Best solution is hacked older ATI_MMC (v8.9) working properly under WinXP Pro SP2 with any newer ATI VIVO cards without TV tuner.
I'm searching from August 2007, but there is not existing same perfect software.
Thank you.
Results 1 to 1 of 1
Cost-Effective MKV Splitting?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Sep 2011, 05:17 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
Media Center PC Software and Overscan
By robjv1 in forum Media Center PC / MediaCentersReplies: 4Last Post: 9th Jan 2009, 21:02 -
Wireless Router Problems Effective Range?
By scustalow in forum ComputerReplies: 3Last Post: 30th Jun 2008, 21:06 -
Best Media Center Software - Cost is not a factor
By dm_0001 in forum Media Center PC / MediaCentersReplies: 10Last Post: 20th Jan 2008, 19:45
