I have made copies of my original DVD's for my daughter. From the beginning I let her watch the original ones, but after a while I noticed scratches and fingerprints all over the DVD surface so I used DVD Shrink to copy some of her favorites. I only copy the movie, not the menues, or the compression will be too big. But I have seen from others that they can copy exactly the parts they want. For instance, you want the menues, you want the deletes scenes the music clip but not the feuterettes. How is it possible to just extract thoose parts, or others and laborate so you find optimal compression. Anyone who knows?
There is a a free software PgcEdit which will allow you to do that, but it is hard to get into, than there is DVD ReMake Pro. This one is easier to learn and at the beginning you can just use "Hide" function to get rid of what you do not like. Later on when you get familiar with VM commands you can delete all unwanted parts and basically reauthor DVD the way you like. For compression software I recommend DVD Rebuilder.
Vobblanker (nuke out unwanted components) > pass to dvdshrink afterwards ... safest bet when you want to recreate a dvd without main title .
Dvdshrink supports clipping in reauthor mode , but menu's are not supported in this mode (fix with pgcedit) . -
Originally Posted by tinker
Re-authoring a DVD with both 4:3 and 16:9 parts
By lordretsudo in forum Authoring (DVD)Replies: 4Last Post: 23rd Nov 2009, 16:18 -
Trying to copy VHS to DVD, but color is black and white at parts!
By MikeyA in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2009, 17:26 -
Extracting parts of a DVD
By jabbo5150 in forum MacReplies: 9Last Post: 31st May 2009, 23:50 -
joining 2 parts of a DVD?
By Itsmeshane in forum EditingReplies: 1Last Post: 23rd Oct 2007, 04:20 -
dvd in two parts
By nig in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 10:35
