I'm going to be purchasing a new home theater system (Receiver and 7 speakers w/ a sub) and will begin demoing speakers next week. I'd like to compile a DVD that has some of the best scenes in movies to demonstrate audio capabilities of speakers. OF course I'll need to preserve the 5.1 soundtrack in each of these scenes and be able to set the start/end point of the scenes I desire to use. I'm wondering:
Which scenes do you all recommend in this compilation. So far I have chosen a scene from Hero (where he cuts the bundles of wood), and a scene from Spiderman 2 where the cops shoot as Doc Oc' after the Bank Heist. What else should I consider?
A side note:
Is there specific guide on this site that you would recommend for instructions?
	You can use dvd shrink in the reauthoring to cut out clips and then also join. And preserve 5.1 soundtrack. See https://forum.videohelp.com/topic198813.html
 I don't know what clips I would use though...
	Thanks Baldrick. I've been checking out DVD Shrink and it seems to be a pretty simple tool. If I'm using multiple DVD's will I need to rip them to Video TS folders first? Sorry, I'm asking this before I even read the guide you've posted. I'll check it out.
	Nope, DVD Shrink can rip and cut directly. But if it's a newer dvd with new dvd protection you have to use anydvd or rip the entire dvd to the hdd with dvdfabdecrypter.
	I just read the guide. So this guide utilizes DVD Shrink simply to extract the desired scenes as clips and then TMPGEnc is used to compile them and author them. I'm assuming that you could use Shrink instead of TMPEnc if you didn't want to add menus...
	Get the opening scene from Saving Private Ryan. Listen for the ricocheting bullets flying past. They'll give a 7.1 (5.1) system a good workout.
  DVD scenes jumping out of sequenceBy click50 in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2009, 01:38
  Help me create a DTS, DD, THX - DVD For Home Theater DemoBy hometechinc in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2008, 17:33
  BVP-4 Demo DVDBy snivlle in forum RestorationReplies: 1Last Post: 11th Apr 2008, 03:13
  DVD Ripping and Missing ScenesBy dimpayne in forum Newbie / General discussionsReplies: 11Last Post: 6th Dec 2007, 13:24
  Cutting scenes from dvd using NeroBy aelfheah in forum Authoring (DVD)Replies: 0Last Post: 16th Jul 2007, 13:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
