I've been out of the scene for awhile, but used to frequent this site for a year straight while I converted my whole analog/VHS collection to DVD. Things have changed.
Even though the quality will be downgraded to 720x480, I'm interested in converting my HDTV captures (either .TS or .MPG from QAM/ATSC sources) to a DVD. This will be re-encoding to MPEG2 and possibly changing the audio down to basic AC3 (if needed) or MP2. This is mostly to hold onto some favorite episodes as they are aired on TV. I'm looking at a program like TMPGEnc DVD Author, Ulead DVD Movie Factory or the like. Ease of use important, but most is compatibility. I need something that will take and understand whatever format HD is broadcast in and not throw up at some unknown audio codec, or the like.
Recommendations? Money is not necessarily a factor, unless I need to buy CCE or some DVD authoring package for $2K ! Then it matters.
-Robert
I guess it would be easiest with ConvertXtoDVD. But not the best dvd mpeg2 converter though.
Looks good. I can convert from TS to MPG/AVI with another tool if needed.
Thanks,
Robert
Edit: 2nd alternative. What's a good program that just outputs any HDTV file into a DVD compatible mpg file which would allow me to use any DVD authoring package? -
The quality is excellent IMO and it is fast. It is free and easy to use so why not just give it a try? It is designed for simplicity and therefore does not have many options. I use it quite often and it has always delivered great results. I find it hard to tell the difference between the converted file and the original HD OTA ts file. I have tried numerous other options and IMO HDTV2DVD is the best.Originally Posted by Valnar
If you want more control over things like bitrate and audio then give Winff a try. It is also freeware and does a good job.bits
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 10:17 -
M-JPEG (HD-) files to show on HDTV
By haschopapa in forum Video ConversionReplies: 3Last Post: 24th Dec 2009, 08:03 -
digital HDTV + DVD recorder show own DVD files?
By Tblossom in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2008, 11:56 -
Divx files on an HDTV?
By snaithbert in forum DVB / IPTVReplies: 15Last Post: 1st Jun 2008, 04:35 -
Multiple HDTV TS files to DVD with SVCD2DVD HELP
By ndoggac in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 18th Jun 2007, 13:21
