Hi, its been a few years since I last converted video to Mpeg2, Im wondering what the best quality converter is? It used to be CCE. I am capturing video from my MiniDV camera via Firewire and I am wondering what program to use to convert it to something I can use in a DVD authoring program.
It depends what sort of image you want.
CCE and HCEnc are similar in finished quality. They both have a tendency towards sharpness, with CCE prone to a noisier image. CCE is still the reigning speed king.
ProCoder (now up to version 3) is softer in it's finish.
Mainconcept is somewhere in between the two, but it does depend on the implementation. The Mainconcept encoder is used in many applications, and the way it is setup in each application can affect the results. For the most part, the implementations in Vegas and Premiere seem to produce better results out of the box than the standalone version.
Tmpgenc is probably the middle ground, although it is still frightening slow.
Everybody has a different view on what constitutes quality. Some people see a sharper, noisier image and perceive this as having greater detail and therefore higher quality.
Some find the softer appearance of some encoders to be more film-like and less soap-opera video.
In short, it is really down to you, and what you want from your encoder.Read my blog here.
Donadagohvi (Cherokee for "Until we meet again")
You might try using FAVC as a front-end, and doing a Predictive Encode. HCEnc cannot run two processes for normal 2-pass VBR, but it can for PQ. I have recently upgraded to a C2Q running at 2.4 gHz (from a P4 3 gHz with HT), and a PQ encode that used to take around 6 hours completed in under 30 minutes. A C2D won't get the same improvements, but it is still pretty damn good for a freebie.
Read my blog here.
MiniDV playback quality on different camcorder
By marksk918 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Dec 2011, 12:08 -
fast speed flv to dvd converter
By nusratjaveid in forum Video ConversionReplies: 2Last Post: 11th Jun 2010, 02:55 -
Best Quality MiniDV Camcorder I could get for £300?
By mkkid28 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th May 2009, 13:27 -
Best format for MiniDV convertion (Mpeg2 or H264)
By bisli29 in forum Video ConversionReplies: 6Last Post: 3rd Dec 2008, 04:49 -
MiniDV to DVD - Questions about quality (SP vs. HQ)
By nikbone in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 16:57
