Results 1 to 9 of 9
    Oct 2007
    Greece
    HELLO.I BOUGHT A SINGLE-LAYER MOVIE DVD AND IT HAS INSIDE 7.5GB. I WANT TO MAKE AN EXACT COPY OF IT TO A SINGLE-LAYER DVD. (IT IS NOT COPY PROTECTED).I DON'T WANT TO SHRINK/COMPRESS IT. HOW CAN I FIT 7.5GB OF MOVIE WITHOUT USING DVD SHRINK OR OTHER SIMILAR PRODUCTS WHO COMPRESS,ENCODE,TRANSCODE BUT DO NOT FIT 7.5GB TO A SINGLE LAYER DVD.THE PROFESSIONALS IN HOLLYWOOD HOW CAN THEY FIT 7.5GB MOVIE TO A SINGLE LAYER DVD? BY USING SOFTWARE OR HARDWARE? ANY HELP WILL BE MUCH APPRECIATED.THANK YOU.
  2. Member Heywould3's Avatar
    Apr 2002
    always on the move
    if its 7.5 gigs then its not a single layer dvd.. what makes you think it is.. in order to make an exact copy you will need to copy to a DVD DL or shrink it to fit a DVD5. no other choice
    EDIT: unless its a HD DVD or BR DVD in which case you can but you're still outa luck because you cant make a DVD from a HD DVD Without compression. they are not the same the resolution and bit rates are different. the file structure is also different as is the Disk it self
    It's not a single layer dvd, it's a dual layer dvd. So buy a dual layer dvdr and copy and burn with Imgburn.
    How do you check if it's a single layer dvd?
    Oct 2007
    Greece
    THANK YOU VERY MUCH FOR YOUR QUICK ANSWER. I THOUGHT IT WAS A SINGLE LAYER DVD BECAUSE IT HAD A LABEL IN ONE SIDE. BUT AS I UNDERSTAND THIS IS WRONG.AGAIN THANK YOU VERY MUCH.
  5. Member Heywould3's Avatar
    Apr 2002
    always on the move
    you can cut in two and make two DVD5s out of one DVD9 if you like but that is a pain.. most of the time if you strip all the extras and sound tracks out you wont have to shrink that much at all. you can get good results if you do a multi pass VBR encode. if the dvd main title is under 2 hours i would give this a shot
    Oct 2007
    Greece
    AGAIN THANK YOU ALL VERY MUCH.
    Apr 2004
    Miskatonic U
    You need to get your keyboard fixed
    Read my blog here.
  8. Member ricoman's Avatar
    Jun 2004
    CT, USA
    Just for the record, don't post in capital letters. It is considered bad forum etiquette, the equivalent of shouting. I think that is what gunslinger was trying to tell you.
    I love children, girl children... about 16-40
    W.C. Fields
    Sep 2006
    Central Illinois
    I don't assume bad manners when someone post in capital letters.......I just have a hard time reading it!
