I have a divx compatable standalone dvd player and have tried burning divx and avi movies direct to dvd but they wont play on my dvd player, it says ´no disk. The dvd player can play these files from my usb stick so why not from a dvd. I am burning the dvd disks with windows media player 11.
Can someone explain what I am doing wrong? I really dont have to time to convert them all the dvd format and bought my dvd player so as not to have to convert everything.
	Maybe you are making a multisession disc. Try close the disc or use another burning tool like CDburnerXp and don't make any multisession, close it and use ISO/UDF mode.
	download something like deepburner free and just burn a regular data disc.
 windows media player should be avoided at all costs.
 if you cant download deepburner free just use windows disc utility to burn a divx file as data to a disc.
 works for me everytime
 windows media player is junk...... (imo)
 www.deepburner.com/?r=download
 choose version 1.8 free version
 when u start the program select 'data disc' and 'no multisession' as the program starts, i used this program for three years, its brilliant.
 also check that your dvd player plays dvd + and or dvd- and check which you are trying to burn. I made this error on my friends pc which only burns dvd+ and I use dvd - and + , It took four attempts to discover my F*** Up!
 you can always burn a typical 700MB avi file to CDr, this should play in a divx dvd player too. Works for me,
 MP4 dvd players are a godsend!
	thanks for advise, am burning as a write.. tried to use CDr but files are too big... will let you know soon whether this has worked using deepburner. CDburnerXP says it is not good for standalone dvd players.. so trying the other first.. Thanks
  Problem burning .avi file to dvd.. Burner tells me file is too big when notBy accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28
  burning a dvd from an .avi file and a .wmv fileBy marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06
  Burning MPG and DIVX to a DVDBy OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 22:12
  Best Divx Ultra DVD Player with Full file Names for MP3 and DivX FilesBy MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00
  Burning AVI file to DVD-RW to play on a Divx DVD playerBy Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 15:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
