I read the help manual in DVD Rebuilder but I don't understand in practice what settings I should use for
"VBR_Bias" and "Quality Prec". Is it OK to just leave the numbers as default? (I already understand about the "VBR_Passes" setting).
See screenshot.
There is one other thing I don't understand. In the install guide for DVD Rebuilder it first details the manual method of acquiring and installing various softwares, and then it says down at the bottom, if you want to avoid all of this work, you can just download the special INSTALLER to install DVD Rebuilder by an easier way. I think that is a bit strange. Why not give the easiest way first and then give the more complicated way? However, after I got it installed, the whole thing chugged away very nicely and about 8 hours later I got my finished DVD folder (I used QuEnc on the High Quality Mode).
Hi-
Maybe because a lot of people already have installed a lot of the pieces needed?Why not give the easiest way first and then give the more complicated way?
The developer, jdobbs, recommends leaving them at default."VBR_Bias" and "Quality Prec". Is it OK to just leave the numbers as default?
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
DVD Rebuilder Settings for PAL
By iamtehsux in forum DVD RippingReplies: 1Last Post: 7th Feb 2009, 12:06 -
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Dealing With DVD Rebuilder: Encoders & Settings to Get Nice Results
By devilcoelhodog in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 21:55 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
