i bought radioshacks Indoor/Outdoor Directional Antenna, it worked great for about two months, now it wont pick up hardly anything, i say hardly anything because i can still get pbs in full hd, its wierd because on pbs my signal strength is 54% and on all the other hd channels its from 5 to 10 percent. is it my antenna or the tower it is receiving signal from?[/b]
I've never heard of an indoor/outdoor antenna so is the antenna indoor or outdoor?
How far are you from the transmitters and are they in the same direction... where are you?
What was the signal quality of PBS befor you lost the othere channels and what was the SQ of the other channels?
Need more information! -
You can also go here to get alignment information: http://www.antennaweb.org/aw/welcome.aspx
Google is your Friend
HDTV antenna questions... again.
By Ai Haibara in forum DVB / IPTVReplies: 32Last Post: 15th Jan 2011, 00:05 -
Very good roof antenna for HDTV that is very low profile ?
By Seeker47 in forum DVB / IPTVReplies: 13Last Post: 21st Aug 2009, 02:20 -
Anyone here ever make and/or try out a homebrew HDTV Antenna?
By Frank-0-Video in forum DVB / IPTVReplies: 17Last Post: 7th Feb 2009, 20:07 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Digital antenna v analogue antenna - does it affect quality?
By Rudyard in forum DVB / IPTVReplies: 14Last Post: 13th Sep 2007, 05:51
