Hi, i am writing this here because i could find another place to write it...
whenever i play any dvd on ""Inter video WinDVD"" the video shows washed, it does not dark as it should, it looks white washed...
but on Windows media player works fine, and divx videos work fine in windows media...
but in VLC player, the video looks washed too...
any recommendations???
I NEED HELP!!!!!!!!!!!!
carlitos287@hotamil.com
Here it is playing in InterVideo Win DVD for VAIO, washed, and it LOOKS UGLY!!!
Here it is Playing in WMP 11 Fine
These are original packaged DVD or authored?
Also, what is your video card?
Do the levels look better on the PC monitor? -
You probably need to adjust the 'overlay' settings. You can usually find them at Display Properties -> Settings ->Advanced. At least that's where they are on my ATI. You can also try turning 'Acceleration' or 'Overlay' (or whatever a given player calls it) off, forcing normal output.
Thanks Man!!
i did not know the overlay did that...
It fixed it... -
But this is not a dvd authoring issue. Moving you to software playing.
Video looks washed out in certain players
By pfxz in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 19:06 -
Problem: Video Black and White in Samsung MM-DG25, How to change video outp
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jan 2011, 12:11 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 15:46 -
Correcting washed out white skin tones
By rch15 in forum EditingReplies: 1Last Post: 12th Aug 2008, 04:22 -
Captured video is super-bright and washed out
By maskull in forum Capturing and VCRReplies: 1Last Post: 20th Nov 2007, 09:23
