Hello all,
I was wondering if anyone knows where to download the latest firmware (v.2.5) for Toshiba HD-A2 HD dvd player.
I downloaded the ISO file from their website but for some reason it will not burn onto a cd.
I've used imgburn, dvd decrypter and a few other programs but with the same results: "invalid or unsopperted file format".
I emailed Toshiba asking them if the ISO file on their website is corrupted but the response wasn't very helpfull.
I know I can order a firmware cd from them free of charge but it takes 2 or more weeks to get it, reason why I decided to ask here in the forum if anyone knows of any other website I can download it from or if anyone has it and can link me to the file, which would be greatly appreciated.
I'm not having any problems with the player, I just like to keep things updated.
Any help will be much appreciated.
Thanks.
T.
Results 1 to 15 of 15
Most likely a burning issue...not a corrupt file. You have to open the image file using your burning software...not just burn the iso to disk as data.
Google is your Friend -
Thanks for your reply, but if you read my post it says I tried burning the ISO image onto a cd using imgburn, dvd decrypter and a few other programs and all failed.
I'm not burning the ISO file itself directly onto a cd, I'm familiar with ISO images and the process of burning them.
I tried it both under Win Vista and Win XP all with the same results.
Anyway, once again thanks for the reply.
T. -
I just used Nero 8 to burn the file and it didn't complain..... I'm assuming it worked cuz like the web site stated it can't be read on a pc and I just stuck the cd in the A2 and it read it just fine. Asked me if I wanted to do the update.
BUT, having said that.
I updated my A2 yesterday via ethernet. Worked like a charm, altho it does take a while and the manual is a joke on how to do this. Far better instructions on their web site.
takes about 15-20 minutes.
Scotty -
I did read your post. But it isn't clear how you burned the iso. Just trying to clear up the obvious. I've also downloaded and burned the iso from the webpage and it works without any issues. FWIW, I'm using Nero 6.x.Originally Posted by tmelo38Google is your Friend
Indeed, you have correctly identified the original poster's problem. That's why the people who say they burned with Nero, which can burn ISOs to CDs, had no problems.Originally Posted by samijubal
Thanks, Scotty and TBoneit for confirming that we can indeed burn ISO images to cd's using imgburn. I've done it plenty of times.
Anyway, I used Nero and it burned Toshiba's firmware update with no problems. Now I'm just wondering why imgburn won't do it.
Thanks to all for the help, much appreciated.
Tony -
Thanks louv68,
I downloaded Burnatonce and it worked with no problems.
Toshiba SD-4700N DVD Player
By pat8671 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 18:06 -
Toshiba firmware
By betocchi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 23rd Nov 2009, 03:30 -
I just got an HD DVD firmware upgrade disk in the mail from Toshiba!
By ebenton in forum Blu-ray RippingReplies: 4Last Post: 30th Jul 2008, 12:50 -
Toshiba Hd-35 HDDVD Player Firmware
By NICEBUD in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 10:41 -
Where can I download firmware files for Toshiba SD-V392?
By guru1 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Nov 2007, 16:02
