Hi there.
I have been struggling for ages now to find a programme that can successfully create a menu for a 4 movie DVD. I have 4 files to put on DVD, i can convert these so that they work, but cannot get a menu to work.
I have tried using DVDstyler.... but this doesn't work, the burn feature just errors and doesn't burn.
I have tried using DIKO (which uses DVD styler) but this also doesn't burn.
It creates a temp folder with all the mpeg files and a number of XML documents but doesn't burn....
I have looked up and down the website, and feel that i must be either missing something easy but also fundamental to the process, or i have just been REALLY unlucky with the programmes i have tried.
What is gutting is that i used ConvertXDIV's latest version, and that worked like a dream but put a watermark in the programme.....
Is there anything out there that can do what i want...?
A simple menu. 4 buttons. one for each video burned to it.
I hate asking such simple questions so many times on the forum, but this is starting to make me feel like i am a little dense!
Any help would be much appreciated.
P
Try GUIForDVDAuthor. It's free and it works. It'll do exactly what you're looking for.
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
DIKO 2.47 Temp folder problems
By chirayuw in forum Authoring (DVD)Replies: 1Last Post: 6th Jul 2009, 05:26 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
How to make DIKO files into DVDFiles ?
By Locutus666 in forum Authoring (DVD)Replies: 17Last Post: 4th Nov 2007, 04:31
