Hi
I wanted to know what sort of devices can be used as a usb device on dvd recorder which have usb connection.
devices such as ext hdd, usb flash, mp3 players. and what content can be picked up from the devices.?
thank you,
It varies by player. It is usually limited to flash drives and/or HDD's. Most players only use them as external storage.
Google is your Friend -
So wich dvd recorder has USB and can support a external HD?
AND can one then copy the recordings to this external HD?
Thanks -
You can browser the DVD Recorders section. Just input USB as an option and you will get a list of all USB capable units. All of the players that I've seen that support USB, can read HDD. I assume since you are wanting to be able to move data to the external USB HDD, then you are also wanting a unit with an internal HDD. Choosing internal HDD will greatly reduce the list.
If you're looking for a recorder in North America (NA) that will output a movie over USB to an external HDD, I think your list will be short... 0!
USB ports on NA recorders are for input only and I don't know of any that recognize external HDDs.
If you can find an older Polaroid 2001G, it lets you install and use external drives if you're handy in that area. AVS forum and some posters there have pics and instructions.
Don't think Hollywood wants you walking around with their movie on a portable HDD or flash drive (even worse).
Rec.709 to RGB24 to Rec.601
By Anonymous344 in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 18:40 -
Converting REC to DVD with multi-languagetracks
By Rob- in forum Authoring (DVD)Replies: 0Last Post: 24th Feb 2011, 10:16 -
Need a Suggestion (VCR, DVD Rec, Upscale)
By Nickhamm in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Sep 2009, 18:23 -
Troubleshooting DV camcorder connectivity
By JohnnyMalaria in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Mar 2008, 02:25 -
can i rec.dvd to the hdd of my dvdr3570 philips?
By fitos in forum DVD RippingReplies: 0Last Post: 8th Feb 2008, 15:10
