Hi
Is any of these versions include all the version enhancements? I thought Vdub had, but it won't open WMV files. I am most interested in transcoding WMV to DIVX....
Results 1 to 10 of 10
You might have to install a WMV plugin: http://home.comcast.net/~fcchandler/index.html
But you still may not be able to open all versions of WMVs.
Try this new experimental version of Virtualdub. It's the only version you need now. It makes VirtualdubMod and Virtualdub MPEG-2 obsolete.
http://www.virtualdub.org/beta/VirtualDub-1.7.X-test5.zip
Check out this thread to find all the input plugins to load different types of fyles.
http://forums.virtualdub.org/index.php?act=ST&f=7&t=14639&s=57c885e0fd0960606d1d745a65a29086
Here are the pluins for MPEG-2, WMV, FLV and QT...
http://fcchandler.home.comcast.net/MPEG2.zip
http://fcchandler.home.comcast.net/Plugins/WMV/
http://www.moitah.net/misc/FLVInputDriver-0_3_0.zip
http://www.tateu.net/software/dl.php?f=qtvd_bin
There is also a download for an AC3 plugin that lets you insert AC3 into an AVI file but I'm not finding it right now.
This version has VBR MP3 support and also allows you to add different types of audio files It also allows frame accurate editing in Smart Render mode and allows transitions with filters in Blend mode and the Curve Editor. -
This guide worked for me - and for many other formats...
https://forum.videohelp.com/topic284288.html -
Open Virtualdub and click the Video tab > click Compression > click on ffdshow video codec > click Configure > under format. look for WMV1/7 and WMV2/8, click on disabled to show the drop down menu and either choose Libacodec or WMV9 and you should be in business.
Obviously you need ffdshow installed on your computer.
As for the plugins, unzip and copy the plugins into the plugin folder in Virtualdub 1.7.X and the files should load automatically.
Also, for other file types that won't open, the guide that Steve Walsh linked to using Avisynth will open them. Using the plugins avoid having to create a script every time you want to open a different file. There are other plugins in the works. Possibly a RM plugin and hopefully a H264 plugin.
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
Avi index error in vdubmpeg2 - how to correct?
By yoda313 in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 20:44 -
vdubmod crash
By RobMan in forum SubtitleReplies: 4Last Post: 31st Dec 2007, 08:22 -
VdubMPEG2: Statsfile problem
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2007, 19:59
