I just bought the PX-810SA drive and I have just noticed in Nero 7.5 the MAX burning speed for a DVD9 +- is 2.4X. Now I believe the drive is rated for 8X.. Would anybody know why I only burn at this speed? The reason this has come to my attention is because this drive (PX-810SA) is replacing my old Plextor 716A. When I use theses same discs in that model I can burn them at 4.5X (which I believe is the maximum write speed for a DVD9 disc). Something else to note when I insert a DVD5 disc rated for 8X, I can burn them at the drives maximum speed of 10X.
Its ratings are here http://www.plextor.be/products/px-810sa.asp?choice=PX-810SA
and should burn 10x rated dual layer media at 10x.. remember the media carries a speed rating tooCorned beef is now made to a higher standard than at any time in history.
Aside from the burners "supported" speeds and the medias "rated" speed. The burner has to have a burn strategy for the media in its firmware. If it doesn't, drives often default to their slowest speed or just reject the media.
Updated firmware may correct the issue.
And just my 2 cents, but ONLY use Verbatim +R DL media. At least if you want the fewest hassles.Google is your Friend
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 18:01 -
burnning dvd
By brenjim in forum Video ConversionReplies: 14Last Post: 2nd Mar 2009, 13:44 -
Burnning iso to DL disc
By leda in forum DVD RippingReplies: 8Last Post: 25th Apr 2008, 19:20 -
Nero 8, Plextor PX716A, PX116A and copying DVD+R (home movies)
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 30th Dec 2007, 09:26 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
