Recently, I had to learn how to use motion tracking in After Effects and how to blur objects in Première. Tracking can be a little annoying as it's very sensible to error, but I manage to live with it.
However now I've been told of a software where you can move an hovering solid or a picture on the rolling video, with either your mouse or even a joystick, all of this in real time. I would like to try it, to check if it might speed up my work.
Any idea which software would that be?
Thanks for any help.
Results 1 to 1 of 1
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 14:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 12:48 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 23:09 -
Control wheel joystick for spinning through video
By deanbrown3d in forum ComputerReplies: 4Last Post: 28th Sep 2007, 02:05
