hi all. I have a screen capturing software issue. It's capturing what i want on the screen. It's saving everything to an .avi file, which i can play back with windows media player. That's not the bad part. There are OTHER things on the screen which it is also capturing.
Photo editors have little utilities where you can erase part of a photo. If you had a best friend at one time, and they are no longer your best friend, you can take them out of a photo. Are there any of the same utilities in any video editors? I just wanna erase ads that are in the capture.
Anyone have an ideas how i would do this? I remember Virtualdub having a plug-in that will erase a logo, like the one from, say, NBC, from a captured tv show, so when you play back the finished product, the logo isn't there. Does anyone know if that would help with what i wanna do? thanks a lot for your help, in advance!
Using a logo remove filter you can blur it away, see https://www.videohelp.com/guides/how-to-removes-logo-text-elements-from-a-video-source-...away-id793#793
weird VirtualDub green screen issue
By magillagorilla in forum EditingReplies: 6Last Post: 13th Sep 2017, 06:53 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
recording screen issue
By George2 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2009, 22:04 -
capture screen with video camera issue
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2009, 09:03 -
Capturing screen image to video - using dedicated card - what software ?
By ullteppe in forum Video Streaming DownloadingReplies: 10Last Post: 12th Oct 2008, 10:34
