Is it possible to use a downloaded .flv file extension with Avisynth directly or does it need to be converted to a .avi first? (Is there an external plug in? )Thanks.
TS
You can use the ffmpegsource plugin for Avisynth to open .FLV files.
http://ivtc.org/new/FFmpegSource-1.13.rar -
If you can play the flv with wmp you should then be able to use directshowsource() in avisynth. If you can't play flv in wmp install FLV splitter and ffdshow.
Was looking to load an FLV file into AVISynth.
http://ivtc.org/new/FFmpegSource-1.13.rar is a dead link.
current version(s) are here http://ivtc.org/new/ Success.
Can't open FLV with Avisynth
By Greensmurfet in forum Video ConversionReplies: 1Last Post: 21st Oct 2011, 18:00 -
Lost ability to use Avisynth script to open .flv file with virtualdub.
By DaneClark in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 11:33 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
creating flv’s using avisynth code
By lindylex in forum EditingReplies: 0Last Post: 5th Jul 2008, 13:09
