How do you 'make' DVD Shrink re-scan a movie? DVD Shrink experienced an illegal operation error and I can't re-scan a movie now..
What do you mean by rescan ? Do you mean open it in Shrink and process it again, or just run it through the first time ?
If it is running it through Shrink the first time, you probably have a bad rip. Rip the original again using DVDFab HD Decrypter (latest version) and try again.
If you are trying to run a movie through Shrink a second time and get this error then I suspect shrink choked on the first pass, and you should start again.Read my blog here.
Move the file to another location, open shrink, go to the file tab and try to open that file again, you will get an error message press ok, now that path is deleted. Move the file back to it's original position and shrink should scan the file again.
Instaed of moving the file renaming the folder should also work -
You can also delete the analysis file and Shrink will rescan the DVD. It's usually located in: 'C
ocuments and Settings/All Users/Applications/DVD Shrink'. The application file is a hidden file, so you will have to turn on viewing of hidden files in 'Folder Options'.
You can just delete them all too. I don't know why it permanently saves them anyway, seems silly to me.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
