    Jun 2007
    does anybody know where to buy PSone jewel case or at least a normal jewel case, none of the really slim ones as they are to small and break easy
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    do you mean the cd cases themselves? There is nothing special about the original psone cases. Are you referring to some that have the clear edge instead of the solid black case that some have? You can just go to any electronic or computer store and they will have normal full sized cases you can grab. i don't know about those special clear ones that have the edge clear if that is what you mean. Maybe if you were a little more specific on what you were looking for someone here could help out a little more.
    Jun 2007
    I just need the cd case itself, the size of a PSone one, some games have fat instruction manuals and wont fit in the thinner cases
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    In that case you should be fine buying a regular sized jewel case. They should be able to fit manuals ok. They are the ones that can hold cd liner notes as well.
  5. Member Conquest10's Avatar
    Chicago, IL
    Do they still sell the regular sized cases?
    His name was MackemX
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    last time I looked they were.....
