I have 4 avi files (a total of 3.5G in size) and in theory my Philips DVP5982 dvd player should play these files as avi on a dvd data disc. But can't figure out how to burn a dvd data disc with Nero 7 after making half a dozen of coasters. Please help out a newbie here. Many thanks in advance!!
What settings have you tried? UDF, ISO or UDF/ISO?
And try on a dvd-rw media. -
I tired every format practically and you might be right about the dvd-rw thing since the NEC burner won't simulate (wrong type of disc error message).
Originally Posted by Baldrick -
Does the Philips player even recognize the disc with the AVIs (in other words, do you get a directory listing in the player)? Is it simply not playing the AVI files when you select them?
If cameras add ten pounds, why would people want to eat them? -
Took Baldrick's advise and switched to a dvd-rw disc and it burned and played on the Philips DVP5982 dvd player!! Thanks, Baldrick!
So I did a search online and indeed found some info on incompatibility issue between a NEC ND-6450A dvd burner (came in my hp laptop) and TDK dvd+r disc. Now I am burning with a Taiyo Yuden dvd-r disc and is going smoothly (antoher 40% to go) and I have a good feeling that it will work.
Many thanks to all you have chimed in, especially to Baldrick.
Originally Posted by Ai Haibara
Can Vista burn data DVD?
By vid83 in forum ComputerReplies: 6Last Post: 22nd Feb 2009, 18:15 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
Cannot change burn speed with DVD data projects
By mekuka_pinasem in forum DVD & Blu-ray WritersReplies: 14Last Post: 20th Aug 2007, 21:43 -
How Do I Burn A DVD Data Disc ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 13:15 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 08:17
