Following on from my previous thread I thought I'd found the perfect answer for converting 720p mkv files to HR avi files while keeping 5.1 sound in SUPER.
All the samples I tried came out great at 960x544 resolution with AC3 sound so I converted a batch of episodes but when I watched one the other day the audio gradually went out of sync until it was about ½/sec out at the end.
At first I thought I'd used the wrong framerate but upon checking both input and output files were 23.976.
Any help appreciated.
What was the codec used in the mkv ? Not everything correctly reads the framerate from AVC encoded mkv files. If the video starts in sync and drifts out over time, generally it means that the framerates have not matched correctly. Open the two videos in mediainfo and check the running times of both video and audio, and see if any of them differ.
Read my blog here.
Input file info -
Output file info -Code:General #0 Complete name : E:\Downloads\x264\3x04 - The Frank Factor.mkv Format : Matroska File size : 550 MiB PlayTime : 20mn 17s Bit rate : 3793 Kbps Encoded date : UTC 2007-10-12 03:23:44 Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Sep 20 2007 09:25:45 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video #0 Codec : MPEG-4 AVC Codec/Info : MPEG4 ISO advanced profile PlayTime : 20mn 15s Width : 1280 pixels Height : 720 pixels Aspect ratio : 16/9 Frame rate : 23.976 fps Language : English Audio #0 Codec : AC3 Codec/Info : Dolby AC3 Channel(s) : 6 channels Sampling rate : 48 KHz
Code:General #0 Complete name : E:\Downloads\3x04 - The Frank Factor.avi Format : AVI Format/Info : Audio Video Interleave Format/Family : RIFF File size : 349 MiB PlayTime : 20mn 15s Bit rate : 2401 Kbps Director : created.with.SUPER(C).v2007.bld.23 Writing application : SUPER(C) by eRightSoft Video #0 Codec : XviD Codec/Family : MPEG-4 Codec/Info : XviD project Codec settings/Packe : No Codec settings/BVOP : No Codec settings/QPel : No Codec settings/GMC : 0 Codec settings/Matri : Default PlayTime : 20mn 17s Bit rate : 2004 Kbps Width : 960 pixels Height : 528 pixels Aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 8 bits Chroma : 4:2:0 Interlacement : Progressive Bits/(Pixel*Frame) : 0.158 Writing library : SUPER(C) Audio #0 Codec : AC3 PlayTime : 20mn 15s Bit rate : 384 Kbps Bit rate mode : CBR
Is there a way of converting the original 720p mkv to a lower resulotion mkv? Maybe XBMC will be able to play it then?
MKV to AVI Audio Sync Problem
By adalect in forum Video ConversionReplies: 26Last Post: 18th Dec 2012, 04:09 -
.mkv to .avi audio is out of sync
By gartzo in forum Video ConversionReplies: 3Last Post: 10th Jun 2011, 17:12 -
problem with mkv audio sync
By movelikeme in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2010, 18:49 -
About MKV to AVi audio(Vorbis) Sync Problem
By afcoff in forum Video ConversionReplies: 0Last Post: 4th Feb 2009, 11:38 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
