I have burnt 3 movies maximum on a regular memorex dvd+r but in a memorex dvd+RW DL i can only fit 4 movies that are 1 hour and 20 minutes. I know that in Extended Play Plus it is possible to burn up to 960 minutes but can't seem to fit more than 4 movies. Thank You.
extended play plus???
Just use a converter where you can specify the video bitrate and you can fit how much you like, like tmpgenc xpress and then author with tmpgenc dvd author or nerovision(be sure that it doesn't reconvert) . See for example https://www.videohelp.com/guides/asafs-avi-tv-episodes-to-one-dvd-6hr-dvd-id1038#1038 . -
You should take into account the quality of your source material. SL discs hold approx. 2 hours of video and a DL disc will hold approx. 4 hours of video. Of course by reducing the vdieo quality you can fit more, it boils down to the quality of your source material and at what point you feel the quality is unacceptable.
As a side note, Nero is not known for it's conversion/encoding quality. You would get better results with other tools.Google is your Friend
Add a intro clip onto a DVD to play before chapters apear NERO VISION
By cp_ozie in forum Authoring (DVD)Replies: 11Last Post: 25th Jan 2009, 19:04 -
Vegas to Nero Vision?
By zapster in forum Authoring (DVD)Replies: 3Last Post: 21st May 2008, 21:29 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 01:47 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 14:45
