  1. https://www.videohelp.com/oldguides/mov2avi
    Im following this guide to convert mov to avi.
    I only have one problem, i dont get any compression format alteratives at all to choose between, its a totalty empty list after "uncompressed" ..why is thath?
    I have the latest verison of Rad Tool
    I would try use mpeg streamclip instead.
  3. Thanks for the advice
    after some long Streamclip testing-sessions it seems like there is however some problem to get exactley what i want with the file
    I have a 298 mb Mov-file..i want it in AVI with the same vid-qualite, oviosly i allso can slide the qualite-bar to
    100 % but then i offcorse must end up with 450 Mb file no matter wich compressor i test, all i demand is an output under 298 Mb (with as great qualite as possible atleast)
    When everybody else than me create AVI my impression is thath the file size is the lowest after wmv format..but the qualite is still really great, and better than mpg and all?
    (P.S i have not touched thoose advanced settings..only the qualite bar)
    guidense would be helpful and greatful
    what video codec are you using in streamclip?
  5. I have tested
    *Intel Indeo(R) Video 4.4
    *Sorenson video(TM)compressor
    The rest of the alternatives showing up in the list sounds a bit weird?
    a hugh hord of "Apple" compressors and perhaps a JPEG-2000-kodare!
    there are however 1 ore 2 comp with moore...this-area-normal-names i have not tested yet
  6. are thoose codecs acceptable?
