I am having two seperate problems, randomly.
The first, is when I use VOB2MPG to combine the seperate VOBs ripped from a DVD, it places the sections in the wrong order. Basically, if there were four sections, it would play section 3, then 1 then 4 then 2 (or some other random combination).
The second, is after VOB2MPG combines the VOB set, Media Player plays the first five minutes of a movie very quickly (in about 2 seconds).
In both situations, the VOB set is fine before hand, and can be played normally in Media Player; however, after creating a single MPG they show either of the problems above; although, not at the same time and not all of the time. Both are random, too. Only about 1 in 5 has a problem.
Any suggestions?
Results 1 to 9 of 9
Post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Here is the log.
I removed some of the duplicate errors [and notated where I removed them].
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title:
Version: 2.5.0.0
Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe
Executable size: 460 KB
Executable size in bytes: 471040
Executable CreationTime: 1/1/2000 12:00:00 AM
Executable LastWriteTime: 1/1/2000 12:00:00 AM
Executable LastAccessTime: 1/1/2000 12:00:00 AM
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 78.5 GB
DeviceID: E:
FileSystem: FAT32
FreeSpace: 10.2 GB
DeviceID: H:
FileSystem: FAT32
FreeSpace: 192 GB
********************* END OF SYSTEM INFORMATION ********************
********************** Input Folder *******************
00:31:02: Volume in drive E is My Book
00:31:02: Volume Serial Number is 39D8-62EF
00:31:02: Directory of E:\School for Scoundrels\VIDEO_TS
00:31:02: 09/28/2007 03:51 PM <DIR> .
00:31:02: 09/28/2007 03:51 PM <DIR> ..
00:31:02: 09/26/2007 11:04 AM 8,192 VIDEO_TS.IFO
00:31:02: 09/26/2007 11:04 AM 65,536 VTS_01_0.BUP
00:31:02: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_3.VOB
00:31:02: 09/26/2007 11:04 AM 8,192 VIDEO_TS.BUP
00:31:02: 09/26/2007 11:04 AM 65,536 VTS_01_0.IFO
00:31:02: 09/26/2007 11:04 AM 687,667,200 VTS_01_5.VOB
00:31:02: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_2.VOB
00:31:02: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_4.VOB
00:31:02: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_1.VOB
00:31:02: 9 File(s) 4,982,773,760 bytes
00:31:02: 2 Dir(s) 10,989,207,552 bytes free
00:31:02: Not enough storage is available to process this command.
00:31:02: E:\School for Scoundrels\VIDEO_TS>
********************** AV Details *******************
file=E:\School for Scoundrels\VIDEO_TS\VTS_01_3.VOB
FormatName=mpeg
Num_Frames=-2147483648
DurationInSecs=-2147483648
Duration=-577014:-32:-22.-7
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=720
Height=480
Standard=NTSC
BitRate=0
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x80]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=5
************************ END ************************
00:31:05: FFmpeg version HEAD, Copyright (c) 2000-2004 Fabrice Bellard
00:31:05: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
00:31:05: libavutil version: 49.0.0
00:31:05: libavcodec version: 51.9.0
00:31:05: libavformat version: 50.4.0
00:31:05: built on Jun 20 2006 11:22:30, gcc: 3.4.4 (mingw special)
00:31:05: Input #0, mpeg, from 'multi:E:\School for Scoundrels\VIDEO_TS\VTS_01_3.VOB*E:\School for Scoundrels\VIDEO_TS\VTS_01_5.VOB*E:\School for Scoundrels\VIDEO_TS\VTS_01_2.VOB*E:\School for Scoundrels\VIDEO_TS\VTS_01_4.VOB*E:\School for Scoundrels\VIDEO_TS\VTS_01_1.VOB*':
00:31:05: Duration: N/A, start: 2533.752633, bitrate: N/A
00:31:05: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
00:31:05: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
00:31:05: Assuming NTSC for target.
00:31:05: Output #0, dvd, to 'C:\Users\Media Center\Desktop\VTS_01.mpg':
00:31:05: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9800 kb/s
00:31:05: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
00:31:05: Stream mapping:
00:31:05: Stream #0.0 -> #0.0
00:31:05: Stream #0.1 -> #0.1
00:31:05: error, non monotone timestamps 211016 >= 38343
00:32:00: error, non monotone timestamps 117847537 >= 117838300
00:32:05: error, non monotone timestamps 124862318 >= 124856212
00:32:35: [dvd @ 0069DF54]buffer underflow
meredith says: [There were about 2 dozen of these errors.]
00:33:12: error, non monotone timestamps 202012293 >= 201977215
00:33:12: [dvd @ 0069DF54]buffer underflow
meredith says: [There were about 100 of these errors.]
00:33:13: [dvd @ 0069DF54]buffer underflow
00:34:31: error, non monotone timestamps 312191820 >= 312178304
00:34:31: [dvd @ 0069DF54]buffer underflow
00:36:47: error, non monotone timestamps 427982995 >= 427964603
00:38:06: frame=145417 q=0.0 Lsize= 4867702kB time=6063.7 bitrate=6576.2kbits/s
00:38:07: video:4441853kB audio:331641kB global headers:0kB muxing overhead 1.973564%
********************** Output Folder *******************
00:38:12: Volume in drive C has no label.
00:38:12: Directory of C:\Users\Media Center\Desktop
00:38:12: 10/27/2007 12:31 AM <DIR> .
00:38:12: 10/27/2007 12:31 AM <DIR> ..
meredith says: [Here it lists the contents of the folder.]
00:38:12: 38 File(s) 30,970,324,343 bytes
00:38:12: 10 Dir(s) 77,155,803,136 bytes free
00:38:12: C:\Users\Media Center\Desktop>
803,136 bytes free
available to process this command. -
Though it shouldn't make a difference, I see you are using an external drive, have you tried running the process with the source VOB's moved to "C"?
There is a space error for the "E" drive too:
I see where the VOB's are being processed out of sequence, ChrissyBoy will need to address that as I'm not familiar with how V2M processes those.00:31:02: Not enough storage is available to process this command.
I wonder if it might be a copy protection issue? What program did you use to rip the disc?Dwight
- Herm Albright
Just throwing this out there....Might be a problem with the drives being FAT32 reather than NTSC. I think FAT 32 has a file size limit that maybe affecting your outcome.
Mark -
Yeah, that's why I suggested moving the source files to "C" which is NTFS. The output folder was set for "C" so the file size shouldn't have been affected there, but I don't know how much 'work' still gets done on the source drive.Might be a problem with the drives being FAT32 reather than NTSCDwight
- Herm Albright
Moving it to the C: did resolve the problem; although, the only difference in the log file was the way it listed the input folder:
12:11:07: Volume in drive C has no label.
12:11:07: Directory of C:\Users\Media Center\Desktop\School for Scoundrels\VIDEO_TS
12:11:07: 10/27/2007 01:07 AM <DIR> .
12:11:07: 10/27/2007 01:07 AM <DIR> ..
12:11:07: 09/26/2007 11:04 AM 8,192 VIDEO_TS.BUP
12:11:07: 09/26/2007 11:04 AM 8,192 VIDEO_TS.IFO
12:11:07: 09/26/2007 11:04 AM 65,536 VTS_01_0.BUP
12:11:07: 09/26/2007 11:04 AM 65,536 VTS_01_0.IFO
12:11:07: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_1.VOB
12:11:07: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_2.VOB
12:11:07: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_3.VOB
12:11:07: 09/26/2007 11:04 AM 1,073,739,776 VTS_01_4.VOB
12:11:07: 09/26/2007 11:04 AM 687,667,200 VTS_01_5.VOB
12:11:07: 9 File(s) 4,982,773,760 bytes
12:11:07: 2 Dir(s) 78,649,749,504 bytes free
12:11:07: Not enough storage is available to process this command.
12:11:07: C:\Users\Media Center\Desktop\School for Scoundrels\VIDEO_TS>
Because it listed them in the correct order, it converted them in the correct order. I will let you know if it happens again, while on the main HDD. -
Glad it worked out.
Dwight
- Herm Albright
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Need a set of hi-res custom matrices for 90 - 110 min avi's...(details)
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Jan 2010, 18:18 -
VOB2MPG Problem - MPG Duration Appears Incorrect
By ScottJ in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 25th Dec 2009, 21:15 -
Do you need all VOB's in the set to be able to run VOB2MPG?
By ttucker in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Dec 2009, 12:24 -
Incorrect Audio stream extracted from VOB2MPG
By TonedAU in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 16th Dec 2009, 20:36
