Hello! I am new to this forum and am hoping that someone can help me. I am authoring DVD with DVD architect and I was asked to put PDF files onto DVD... is it possible? If so, how do I do that? I use Vegas 7.0 for editing.
Thank you so much!
Results 1 to 9 of 9
Yes, you can do this, although I can't tell you how to use these specific tools. Basically just create a directory at the same level as the AUDIO_TS and VIDEO_TS directories and call it something like DOCS and put the PDF files in that new directory.
Thank you jman98 for your advise. I did try your advise but burned DVD does not recognize (show) the DOCS folder in the directory.....
Any advise on this?
I believe a dvd player only expects to find video content, try opening the disk in windows explorer and see if the folder is there, double click on it to see if you can access the pdf files.
Hi SWBisbee! Thank you for your advise too. Yes I did try opening the Disc in windows explorer but didn't find the folder which contains PDFs....
Hi - Look to the last reply here: https://forum.videohelp.com/topic338556.html#1763464
Pol -
Hello everyone! It worked! Thank you so much. Again I am new to this forum and am very appreciate everyone's help.
Need to add pdf's to authored 9GB DVD then re-compress for 4.4GB disc
By stretchweider in forum MacReplies: 7Last Post: 4th May 2016, 12:40 -
DVD authoring program that will add Macrovision
By Nolonemo in forum Authoring (VCD/SVCD)Replies: 19Last Post: 31st Oct 2010, 03:26 -
Add audio-track to DVD WITHOUT re-authoring
By vk_dk in forum DVD RippingReplies: 1Last Post: 14th May 2010, 19:57 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 12:22 -
PDF Files on DVD
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 04:06
