How do you convert VRO_MOVIE files to VOB files as I took a video with my camcorder which I used a dvd-ram mini disc but my home dvd player wont accept dvd-ram
Not sure what to do now but long term solution is to record to standard disc in video mode if you can.
Some camcorders include software that, when installed on a PC, will allow you to transfer video to the computer's HDD via a USB connection. Assuming that computer has a DVD burner, and has the right software installed, you could then edit and author the transferred video to a DVD. If you have not already done so, check the documentation and accessories that came with your camcorder to see if it does. There is plenty of information about the rest on this site. Best of luck to you.
There's Vro2vob, a shareware from Japan. No English, but not too hard to figure out. It converts the contents of the ram disk to a regular dvd structure on the hard drive.
http://www2.mnx.jp/~dle871/
Problems Creating New Projects From .VRO/.VOB Source Disc
By RocknRollElitist in forum Video ConversionReplies: 0Last Post: 29th Oct 2010, 14:29 -
VRO to VOB Redux
By sambat in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2009, 17:20 -
Vro to Vob conversion?
By marty mcfly in forum Video ConversionReplies: 6Last Post: 30th Oct 2008, 21:16 -
how do you convert a vob file into a vro file?
By johnsteed in forum Video ConversionReplies: 29Last Post: 13th Sep 2007, 07:12 -
vro to vob on a mac x
By crocker5731 in forum DVD RippingReplies: 0Last Post: 18th Jul 2007, 20:14
