hi,can someone help,
while trying to play avi files in Nero 7 sound is out of sync, so when file is burnt to disc that to is out of sync.When i play file in windows media player syncing is ok. How can i fix the Nero problem because i need this program to burn![]()
hopeful thx
Drop the AVI into Gspot 2.70 and see if the small green 'VBR' sign lights up in the lower left area. If so, MP3 VBR audio can cause sync problem when converting to MPEG or DVD formats. MP3 VBR audio is common with Xvids and similar AVI types off the net.
If you are not converting to MPEG, then you may have a different problem. Bad sync can also be caused by missing frames, corrupt video or audio or bad cuts and pastes when editing.
And welcome to our forums.
Also, Nero is not known for it's quality conversion/encoding of video. There are many other tools that do a much better job.
Just look in the HOW TO - Convert section for guides and more information.Google is your Friend
Syncing sound when interleaving won't help
By higgins327 in forum AudioReplies: 2Last Post: 1st May 2011, 09:58 -
is it possible to author a BR usig m2ts files without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 6Last Post: 5th May 2010, 10:23 -
rmvb to avi, sound syncing problems, any tips or tricks
By dudeboy in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 08:19 -
Date in label field in Nero7
By colorbars in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 03:34 -
Syncing better sound to a DVD - I need someone to do it for me
By Salva Veritate in forum AudioReplies: 13Last Post: 8th Sep 2007, 16:48
