Hi!I'm new to the forum - and in need of help!
Have just bought the LG V271N (that was the name on the package) wich is a combo player.
I've tried the hack that's listed on the site for the LG V271 (with the '0000') but it didn't work.![]()
Do you guys have other hacks that might work for this?
I have a region 2, but want it to play my region 1 dvd's as well.![]()
Any known region free codes will be in the DVD Hacks section. There is often differences between models, so you would need a code specific to your model.
Google is your Friend -
I've tried the only hack in the DVD Hacks section, for LG V271 - but it didn't work, unless I somehow got it wrong
The 'DVD region code selector' didn't show on the screen at all.
Region code hack posted by Techbay, May 28 2007:
Turn on the unit and open the tray. Press 0000 on the remote to access the DVD region code selector.
Change the EEPRom code to 0 to remove the region lock.
Enjoy
Maybe I shall try every code existing for LG - players? would that work?
Region free hack samsung dvd player ht-d453hk
By nhe in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Apr 2014, 21:31 -
Region Free Hack Code for Samsung R3 DVD Player P255K
By Scoop in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 00:01 -
need region free hack for samsung dvd player p171
By oztib in forum DVD & Blu-ray PlayersReplies: 23Last Post: 9th Aug 2010, 08:21 -
Region free hack for Philips PD9000D/37 portable DVD player
By anu in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jun 2010, 03:31 -
Converting Magnasonic Dual DVD/VCR player to region free
By JOKER1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jul 2008, 14:50
