Hi All
Now that I've had my HV20 for Many Months I figured I should try to get some vid on my Hard Drive..
To Capture I read a decent poster talking about HDV Split.. So I downloaded it every thing seems fine
But as I hit play from the HDV Split Software the camera goes on but then shuts down in 5 seconds?? Everytime
I cannot figure it out... The Camera is fine if I unplug the firewire no-issues the camera plays
Plug it in and try to play/rec...and the camera just shuts down...
Thoughts ?
Thanks in advance...
Go into the camera's menu and make sure that you do not have DV LOCKED selected. You should select HDV/DV.
Is your computer capable "doing" HDV ???
HDV requires a lot of horsepower.. -
Your computer stats show WinXP sp1. You need sp2 to capture HDV.
Laptop shutting down...
By alintatoc in forum ComputerReplies: 7Last Post: 6th Feb 2010, 15:31 -
Computer keeps shutting down
By mac71671 in forum ComputerReplies: 8Last Post: 29th Jan 2010, 10:45 -
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 09:24 -
hv20.com down?
By 2Bdecided in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Feb 2008, 08:20 -
CANON HV20
By onionfish in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2008, 17:28
