Greetings.
I currently own a MOTU 828 MKII, 5 KRK RoKit 5 Speakers and a Rokit 10 Sub. I have the MOTU set up where there are 6 outputs feeding each speaker directly. This way I can monitor 5.1 mixing from Soundtrack Pro 2. This is for mixing 5.1 for a film, not music.
I read an article on Bass Management and it says I need to route the 5 channels to the sub, as well as the LFE channel (so he sub can receive the LFE channel and the sum of the main-channel bass)
That way I can hear the bass (anything under 53Hz from the main 5 speakers). As of now, my 5 speakers are not feeding to the sub, only the LFE.
So the only bass I get from my main 5 speakers are anything down to 53Hz. Anything below that, I cannot hear unless I put that in the LFE (which is not correct unless its for an effect.)
In a normal 2.1 setup, one would have the main outputs from the MOTU going into the sub and then out to the main two speakers.
How can I route my 5 speakers through the sub (as well as the LFE channel)?
	looks like a quick way to reduce the impedence to 0 and blow your amp. why not rustle up 5 studio quality monitors, skip the crossovers, and output the bass where it's supposed to go? --
	So you're saying just get $1300 speakers that are able to produce a LF of 39Hz and only use the Sub as the LFE (anything below that LF range)?
	yes if it's in the budget. simple, easy, no messy wiring and it will make the total audio output sound more natural. --
	I have KRK's that are 20KHz to 53Hz that are nice. Most speakers are in that range, except the JBL's, which go down to 39Hz. When I crank them, I hear a little base. I think I'm just used to mixing with my Logitech 5.1 satellite speakers that have a sub. The KRK's are soooo clear.
 So the diagram isn't something I need to worry about unless my monitors cut off any LF?
	right. most 5.1 or dts audio systems will take care of sending the low frequencies to the sub if the owner wishes/or sets it up that way by selecting small surround speakers. --
  My Bass in a Cam Recording is to loud ?By picklepie90 in forum AudioReplies: 6Last Post: 1st Mar 2011, 02:04
  How Can I Fix This Bass Rumble? (Example Included)By MrJacobAngle in forum AudioReplies: 4Last Post: 13th Jul 2010, 20:09
  Removing Bass From Video?By Tel in forum RestorationReplies: 11Last Post: 19th Jan 2008, 16:19
  Windows Power Management QuestionBy NBninja8 in forum ComputerReplies: 5Last Post: 12th Jan 2008, 23:51
  too much bassBy nick088 in forum AudioReplies: 3Last Post: 18th Aug 2007, 00:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
