Hey guys. Well I reformated my pc from vista back to xp sp2. I've installed the latest codec pack and when i play an avi file that uses xvid codec, the picture goes all haywire. The most obvious is a green vertical bar near the left side of the screen, also some colours gets seperated and shows some kind of a ghost next to the actual object (like the outline of a character gets copied and shown next to the character) also there are yellow stains everywhere. However, when I take a snapshot in VLC, the snapshot shows it's fine and doesn't show any problems.
I played the avi file in divx player, it was playing fine without errors. However the player is very buggy and freezes a lot.
I am not sure why this is happening it's the first time I've seen it. Some other avi files that also uses xvid shows fine.
EDIT: I took some photos of my screen just to show you guys what I am really seeing in VLC and WMP.
Codec packs often screw up more than they fix. Uninstall (if possible) the codec pack and/or just the divx codec. Then download and install the latest divx codec from divx.com.
Google is your Friend -
Latest codec pack? what codec pack? As krispy kritter says does several codec pack mess up the playback. I would uninstall the codec pack and JUST install the xvid codec or use ffdshow.
I used the combined community codec pack. I'll try that one and see how i go.
ffdshow is the best, I have used it for years without any problems.
Probably some conflict with some other codec or wrong ffdshow configuration. But you don't need it if it works fine with the standard xvid codec and other codecs.
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 17:31 -
To Remove Title in AVI-XviD videos
By shans in forum EditingReplies: 6Last Post: 28th Mar 2011, 21:21 -
Looking to convert avi ( xvid ) to decent quality flv videos
By mordor in forum Video ConversionReplies: 0Last Post: 26th Oct 2009, 03:56 -
a new program that converts videos to 16:9 without screwing up the picture
By Michael1T in forum Video Streaming DownloadingReplies: 34Last Post: 23rd Jul 2009, 07:19 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 16:08
